Using SCXI-1531
We are struggling with SCXI-1531 installed in SCXI-1000. We can definitely collect data through the traditional DAQ.
If we try to use DAQmx to collect them, however, we can't get any signal from the device. Also, sometimes we can't reset the device but sometimes we can. Any ideas or suggestions?
By the way, our DAQ card is NI PCI-6024E.
Best,
Jay
(3,213 Views)
Does MAX verify the SCXI chassis and show the module as installed? - Mike
(3,192 Views)
Yes, it does.
Jay
(3,182 Views)
Hi Jay,
Before you can use your 6024E in DAQmx, you must re-associate the card with the DAQmx driver.  The steps for this are outlined in the following KnowledgeBase article:
How to Re-Associate Your Traditional DAQ Device with the DAQmx Driver
Jim Schwartz
(3,171 Views)
