Using SQLplus command in LabView Database toolkit
Hi ,
I would like to ask something but before that this is my set up background
OS          : Win 7,
LabVIEW : 2012
I have successfully connected with Oracle database using Labview Database toolkit.
The problem now is since I need to query the data from the database,
it will takes time for the labview to process it (since there is so much data in a specific table),
let say that the table in database is "Serial Number", and the data that I want from that table is "SN123"
if I query the data from that table, the labview will process it in a long time since it will not only give me "SN123" but also other data inside the "Serial Number" table.
(Refer to attachment)
but if in SQLplus, there is a command that can be execute to specifically call the "SN123" data,
For the SQLplus, the steps to retrieve the data is like this:
1. Key in the command to get the ID of the "SN123"
2. Key in the command "SN123" ID to retrieve the data.
I wonder if there is a way to put this command on labview database so it will be faster to retrieve the data.
Message 1 of 1
(2,521 Views)
