Using Shared Memory in LabVIEW
I'm trying to use shared memory with LabVIEW. Can I use it, a DLL in C with LabWIEW for use shared Memory?
(3,850 Views)
Lidia,
Check these out (for memory mapping):
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000006A1D0000&UCATEGORY_0=_318_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=build+cvi+shared+dll&USEARCHCONTEXT_QUESTION_S=0
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000005BC10000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTION_0=Communicating+Between+Built+LV+App&USEARCHCONTEXT_QUESTION_S=0
But in general you don't need to use this when you use dll's. It is used to
share data between different processes. If you need LabVIEW data in a dll,
try to pass it as a pointer to an array, or as a string pointer.
Wiebe.
"lidia" wrote in message
news:506500
000008000000DCE70000-1079395200000@exchange.ni.com...
(3,850 Views)
