Using System Exec.VI to pass Dir Paths with spaces to Program
When using the system Exec.VI, I am trying to call a remote executable program which takes in a source filename and a  destination filename
I am running into diffculty because the command line interface does not like dir folders with spaces in their names.  Does anyone know how to remedy this?
cmd /c "C:\Labview Programs\Georges Program\report.exe"  SourceFile DestinationFile
Problem exists when I have Sourcefile defined as C:\Labview Programs\source.txt due to the space in the directory...
(4,973 Views)
Hi id.  Did you try passing the string to system exec.vi including the double quotes?
Here is a string we pass to system exec.vi, copied directly from the string constant:
net stop "national instruments variable engine"
works just fine.  Another option to try would be a single quote.  Or are you having a different error?
Matt
(4,961 Views)
I know this is an old post, but I experienced the same thing as the OP, and for anyone trying to figure it out, the caret key can help you pass the correct characters to the system exec command.
For example... I had the command:
cmd /k "..\Get Data\My Data.exe"
To get it to work, I had to change my string to:
cmd /k ^"..\Get^ Data\My^ Data.exe^"
(4,669 Views)
