Using Tessract DLL
I use Tesseract.exe in my application (LV13) rather rudimentary (with repeated disk access) and I would rather use the DLL (or .NET) available.
But I did not understand everything about the classes used ...
Here is the rudimentary version but works well:
And what I would like is something like below (only for example, I'm not sure for the functions used...) :
Would someone help me on this subject ?
Thanks.
(5,848 Views)
can you upload the dll file with the command list..
CLD Using LabVIEW since 2013
(5,828 Views)
Hello  kartiknattar,
Thanks for your answer.
Attached the files for .NET and DLL.
(5,812 Views)
Do you have a header file with the dll? Without the header file we cannot wrap the dll file as vi as we do not have full command syntax .... or any pdf or document file which contains the command list?
(5,807 Views)
(5,796 Views)
Can you share the Tesseract.exe with me.
Thanks a lot.
Fred
(4,619 Views)
Hello Fred,
Do you mean the file to install the language ?
Or do you need information ?
Bruno.
(4,582 Views)
