Using Traditional NI-DAQ device and NI-DAQmx device at the same time
Dear all,
I have LavView 2009 and am trying to use both traditional NI-DAQ (to collect data from an accelerometer which is connected to SCXI 1000) and NI-DAQmx (to collect data from a load cell and electrical stimulator which is connected to NI USB-6259 BNC) at the same time. Since the accelerometer which I have needs a power supply, I cannot directly connect it to my USB-6259, but should use SCXI 1000. Any suggestions? If possible, I want to collect all the data only through USB-6259 BNC.
Best,
Jeong
(3,033 Views)
If you look at the data sheet for  the SCXI 1000, you will see that it is supported by DAQmx.  There is no need to use traditional DAQ in your program.
(3,030 Views)
Hi, DianeS
Is there any way for me to connect SCXI 1000 to USB-6259 so that I don't need to use a DAQ card?
Jeong
(3,026 Views)
Not to my knowledge, no.  I might be wrong about that, but the cabling doesn't match up.
(2,991 Views)
Hi Jeong,
Only mass termination USB devices can control the SCXI chassis. However below are a couple other suggestions and considerations- hopefully it helps!
The SCXI-1000 is the chassis and does not do any of the acquisition.  I will assume you are using one of the Accelerometer modules for the front end filtering for your acquisition.  This would be preferred versus acquiring your accelerometer data with a USB 6259.  In addition to the excitation supplied to the accelerometer, there is the additional filtering and simultaneous scanning if using more than one accelerometer.  The USB-6259 will multiplex through your channels and does not include the built in filters.
The actual acquisition is being performed by the device controlling the SCXI chassis.  Are you using a PCI multifunction DAQ device or SCXI-1600 for control?  If you are using a 2 connector DAQ card, for example like the PCI-6254 you can control the SCXI chassis with connector 0 and cable to a breakout board, i.e. SCB-68, from connector 1.
h_baker
(2,971 Views)
