Using Unit Test Framework with State History
Hi All,
Consider a very simple Set/Reset VI that has the following prototype:
Q = Set_Reset (Enable, Set, Clear)
The latch stores Q in an initialized shift register.
100% code coverage is easy with three inputs.  However, I've been unable to implement a unit test that validates this code in NI UTF.
For example, consider the following 3 cases :
  • Case 1
    • Clear = F
    • Enable = F
    • Set = F
    • (!Q)? Pass : Fail
  • Case 2
    • Clear = F
    • Enable = T
    • Set = T
    • (Q)? Pass : Fail
  • Case 3
    • Clear = F
    • Enable = F
    • Set = F
    • (!Q)? Fail : Pass
Notice that Cases 1 and 3 are the same except for the P/F criteria.
I could leave the shift register un-initialized.
I don't want to change the behavior of my code modules to unit test them.
I could use a conditional disable structure around an initialized and un-initialized feedback node and set a "UTF" symbol for the latter.
While the modification is simple enough with this code, this is simple code.  Also, I'm not really unit testing the code that will deploy.
I could use build a user-defined test that loops the module through all cases (retaining the module's state) and evaluates Q each time it iterates.
From what I've seen in the 2012 user-defined test example, this investment is an order of magnitude greater than building the latch itself.
I'd like to think I'm missing something.  What's the right way to unit test a VI that implements dynamic state?
Thanks for any advice,
Steve K
(2,776 Views)
I stumbled upon a similar problem as I am using feedback nodes quite often to detect changes and store internal information in SubVIs. So there is no simple solution?
(2,666 Views)
I've not heard or seen of one 😞
Please let me know if you do.
-Steve K
(2,652 Views)
