Using VI Scripting to find value of Array of String Constants
How can I find the value of an Array of Sting Constants using VI Scripting? The included code only returns one of the values in the Array. Is there a way to return all the values?
—Ben
Prevent your computer from sleeping programmatically!
Use Power Requests
Download from GitHub
(3,317 Views)
Accepted by topic author Ben_Manthey
You don't want a string or string constant, you want to find the array constant, and use the Value Property node on that.
(3,292 Views)
Here's what the code looks like for RavensFan's suggestion:
(3,262 Views)
