Using VI "Load XML File", why does regular expression "1|2|4|8|16|32|64|128|256" not match "256" ?
In my XSD file, I have:
	<xs:attribute name="bufferSize">
		<xs:simpleType>
			<xs:restriction base="xs:unsignedInt">
				<xs:pattern value="1|2|4|8|16|32|64|128|256"/>
			</xs:restriction>
		</xs:simpleType>
	</xs:attribute>
In my XML file, I have:
	<myElement bufferSize="256"/>
However, when I invoke VI "Load XML File", I find the following parse errors:
   Message: Datatype error: Type:InvalidDatatypeValueException, Message:Value '256' does not match regular expression facet '1|2|4|8|16|32|64|128|256'.
I have also tried:
<xs:pattern value="(1)|(2)|(4)|(8)|(16)|(32)|(64)|(128)|(256)"/>
(3,392 Views)
I think instead of quotes you should use square braces:
[1|2|4|8|16|32|64|128|256]
Though I'm not too familiar with XML, that is how you would do it with LabVIEW
Cory K
(3,377 Views)
I'm not hip to XML, but I know that your expression will match the 2 in 256 before it matches what you're looking for.  You'll need to reverse the order of your regular expression.
Jim
(3,360 Views)
Thats a good catch.
Of course Jim would jump all over a regex question Smiley Wink
Cory K
(3,350 Views)
