Using VNC with LV7 and problems with menu's
Hello All,
I would like to use VNC to remotely control an application. The problem is I can't see any of the scroll down menu's on block diagram items. Does anyone know of a solution or alternative program for this problem?
thanks
David
(2,601 Views)
Sorry everyone. Premature posting.
Immediately after posting I stuffed around with the VI settings and found that if you disable the "Menu Animation" option it works just fine.
(2,601 Views)
