Using WinSpec 32 in LabView
Hi ,
I'm very new to LabView and so am i to WinSpec! I was wondering if there was an ActiveX control that could be used to control WinSpec in LabView? As i spoke to the tech support at princeton instruments, and they said there was no ActiveX control available. But i do see posts here on it so i wanted to clarify. If so, can anyone point me to some documentation/sample codes available for it's use? Thanks a bunch!
(5,613 Views)
There may not be an ActiveX control, but according to this, there's an ActiveX class available. It just means you use the Automation Open function to instantiate it, rather than having a front panel ActiveX container.
(5,610 Views)
