Using Wrapped VIs From Imported CVI Library: LV Upgrade a Problem?
My instrument is the Agilent E5270B SMU mainframe, and (thanks partly to posts on these support boards) I was able to use the Import Wizard to create a library of "wrappered" VIs out of the CVI library. I do notice I had to use the 32-bit version of LabVIEW to use them.
I have been on LV2017 and would like to upgrade to a newer version: However, am I going to need to re-import this set of VIs in the newer version, or can they be converted as part of a mass recompile? Because they are not natively LV Plug&Play, I am concerned that all the links won't translate smoothly.
Message 1 of 1
(1,275 Views)
