Using a C dll!?
Hi!
I have a dll consisting of the following simple code:
int __stdcall Array_dll_test(int data1, int data2)
return (data1 == data2);
How do I set up my CLF in LabVIEW? I have tried several possibilities
but LabVIEW can't seem to find the function in the library... Please
help!
/Stefan
(4,375 Views)
Sounds like the C++ compiler is mangling the function names - try renaming
your source file with a .c extension instead of .cpp and re-compiling.
Visual C++ will not mangle the function names on a .c file.
You can use the Quick View utility in Windows to look at the function names
in your dll if you wish to verify the function names are in the dll
correctly.
Chris
Stefan Eriksson wrote in message <37A052C0.7C29266D@home.se>...
>Hi!
>help!
>/Stefan
(4,375 Views)
Stefan Eriksson a écrit dans le message <37A052C0.7C29266D@home.se>...
>Hi!
>help!
>/Stefan
If you want to prevent function name mangling, you can change your source
filename extension with ".c" but if you want keep ".cpp" extension you can
write:
extern "C" {
around function prototype and around function bodies.
(4,375 Views)
