Using a DLL I've built from labview
I've never built a DLL before so I have decided to do it today. Actually I have no problems building the DLL itself but if I want to reuse it with the Call Library Function node and I select the function then instead of seeing double Adding(double A, double B) like I've seen when I have set up the build I only see void Adding(void );
I guess this must be something trivial but I can't figure it out. What would be the way to see the parameters as well in the Call Library function node?
(no such problems when I have created a .net assembly, that one shows the parameter names as expected)
Thx.
(1,789 Views)
Accepted by rolfk
You must configure Call Library Function manually and add your parameters:
, or you can use Wizard (Tools->Import->Shared Library (.dll)), then parameters will be obtained from the header:
(1,729 Views)
Thanks mate, this is what I was looking for.
(1,702 Views)
