Using a Multicolumn Listbox To Retrieve Selection Items
that can be accomplished.  Try using a mouse down filter event on the listbox.  Use the Point to Row Column method to get the row.  Check to see if the value is already in the listbox array.  if so remove it.  If not, add it.  Update the display of the listbox.  Then discard the mouse down event.
aputman
Message 11 of 19
(3,805 Views)
DavidStevenson wrote:What I would like is this usage without needing to hold down the cntl key.
But that goes against every single UI I have ever seen.  That would just confuse users.
Message 12 of 19
(3,803 Views)
aputman: Thanks, I will have a play with that. ( the lazy part of me says any example code?  8-) )
crossrulz: It depends on whether the machine has a keyboard.
Message 13 of 19
(3,794 Views)
OOOOOKKKKKKK. Smiley Very Happy
aputman
Message 14 of 19
(3,784 Views)
just mouse down on any row, shift reg saves values...
Message 15 of 19
(3,770 Views)
My thanks to both of you.
Message 16 of 19
(3,734 Views)
I know this an old thread, but could somebody point out my obvious mistake.
I was looking at the example posted by apok and have on major problem.
When ever I put a MCL onto a front panel and look at the "value" property node I only see it giving my a long 32 int not an array. I asumed that to get an array out of value I need to set someother property, but after an hour playing I cannot find which one. Help please
Danny Thomson AshVire Ltd
Message 17 of 19
(3,616 Views)
You need to right click>>Selection Mode>>Data type>>Array
___________________
Try to take over the world!
Message 18 of 19
(3,607 Views)
Thank you for the quick reply.
Really do not know how I missed that one .
Message 19 of 19
(3,600 Views)
