Using a Multicolumn Listbox
Hi, does anyone here can help me to put my data on to a  Multicolumn Listbox, I'am trying to make a program tha all my data will be dumped/Display  Using a Multicolumn Listbox with continous gathering of  data , and every data gathered ,the listbox will also update until the program is done.
Thank you and Best regards,
syrpimp
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
(6,594 Views)
I am not sure what exactely you are looking for based on what i understood what I can say is
1. Use property node "Item Name"
2. build your data as 2D andput data to multocolumn list box
With Regards
Miraz
Kudos is better option to thank somebody on this forum
(6,586 Views)
Is there a specific reason you are wanting to use a multicolumn list box? I all you need is a tabular data display, a string table indicator would be easier to use.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(6,582 Views)
Is each row in your display some kind of collection of properties of an object?  Like say each row is a UUT and each column is data about that UUT.  Here the user selecting a row, or even highlighting a row programatically seems like a good idea so a MCLB should be used, otherwise just use a table.  Visually a table and a MCLB can look the same to the user.
(6,547 Views)
Exactly HOoovahh, I like to Display test item test result and every test , it should be put into row
syrpimp
(6,527 Views)
Then a table well work fine, and it is easier to work with because from the standpoint of the data value written to it, a table is just a 2D array of strings.
You can also show column and row headers if you want. You can insert label into the headers by either simply typing into each cell, or there are properties for them as well.
Mike...
LabVIEW Champion
(6,501 Views)
As Mike mentioned it is easier to work with table. The only benefit using multicolumn listbox in this case are the row symbols. You can use them to indicate for example if a test failed, or passed, etc... But this needs a little bit more work.
You can find all available listbox symbols in the Dialog & User Interface functional palette (see the Listbox Symbol Ring Constant). They can be assigned using the Item Symbols property.
Nick
(6,440 Views)
