Using a PC4350 DAQ and/or a PC-LPM-16/PnP DAQ under Labview 7.1
Both of these DAQ's are ISA bus devices, and are not listed under the
DAQmx set.
It has been a futile search on how one sets up a measurement procedure
to take data when they aren't in the DAQmx set.
I need to set up a measurement system , running under W 2000 / Labview
7.1 full development system for 0-10 volts and for 4-20 Ma inputs .
The 4-20 Ma inputs are from a group of Dwyer magnehelic pressure
sensors
I need to do ~ 24 measurements, probably in 2-3 seconds, and want the
output to be loaded into a format for importing into Excel
I have tried to install the PC 435x drivers , but they don't seem to be
installed in the vi library with the rest of the vi's for other DAQ
cards.
Thanks in advance
Dan
(2,726 Views)
The PC-LPM-16/PnP is not supported by NI-DAQ 7.0 or higher. In order to use this board, you will have to install NI-DAQ 6.9.3 or older (see Versions link below). This will use the Traditional driver. As you noted this device is not supported by NI-DAQmx. There are numerous examples that ship with LabVIEW that should illustrate how to use this board. As for the PC4350, what version of the driver did you install?
NI-DAQ Version Reference
(2,726 Views)
