Using a VI through Delphi .NET
I'm wondering how to call a VI directly from Delphi .NET. I know there
are some ways to use a VI in my own application. None of these is
appropriate, neither the way over a DLL nor the usage of the ActiveX
method.
Is it possible to include the VI direct into my Program? The Runtime
Environment of Labview is installed and considerably there is a way to
start the VI with some parameters and read the returned Value(s).
If there is any chance to do this there would be a powerful interesting
feature for the applications using Labview VIs.
(3,225 Views)
Nobody?
There must be a way with the Runtime Environment.
(3,214 Views)
My question is why building the VI into a DLL or using the ActiveX server interface is not acceptable. The ActiveX server interface would require that the full LV IDE be installed, so I can understand that would be an issue, but why not building the VI into a DLL? The reason I ask is that this is the method we offer to provide the necessary glue to call the VI from outside the LV environment.
(3,203 Views)
