Using a counter channel as a DO
Could you please tell me if there is any possible way to use a ctr channel of an 6212 OEM as a DO channel.
Thank you in advanced
(2,404 Views)
Many of the signals associated with counters can be routed to I/O using PFI's.  See chapter 7 of the manual for details on which signals can be routed through the PFI.  https://www.ni.com/docs/en-US/bundle/usb-621x-manual/resource/usb-621x-manual.pdf
(2,391 Views)
