Using a menu ring to select DAQ device channel and indicator
New user here. I am using the DAQ assistant with multiple analog inputs. I would like the front panel to have a menu ring where the user can select which channels are to be active. Also, this corresponds to a single graphical indicator.
Currently I have a VI that displays all channels each with its own indicator. I want to simplify the front panel so that a user can simply use a menu ring to select and focus on what he/she is interested in. Is it possible to use the Select Signals Express VI to implement this?
Thank you!
(2,585 Views)
Drop the DAQ Assistant or convert it to regular DAQmx functions. The physical channel control does all that. Just look at the shipping examples.
(2,576 Views)
