Using a stored array element
I want to use  a single element seqentially starting from Index zero in an array(1D) and use that element. How can I choose one element each time from that array and use it.?
Ravi
Message 1 of 14
(4,627 Views)
Assuming you use a FOR loop, it is sufficient to autoindex into the loop and you'll get one element per iteration (starting with element zero) until you run out of elements, at which time the FOR loop ends.
For more complicated needs, just use "index array" and wire the index to simething that increments at the desired rate (e.g. the [i] terminal of a loop).
Message 2 of 14
(4,620 Views)
Thanks altenbach,
Does that mean that i just connect the autoindexed point on the for loop where I can output the elements to my further string in which each element will be automatically formatted into the string.
If the first element outof the forloop is say 1.0, i connect it to a format string input CURR%f, its first output will be CURR1.0 and so on as the for loop iterates. have I interpreted it right?
Sorry if  I sound too clumsy.
Ravi
Message 3 of 14
(4,615 Views)
Yes, like everything is LabVIEW, it's that simple!
You don't need to wire N, etc.
Message Edited by altenbach on 09-17-2007 10:33 AM
Message 4 of 14
(4,611 Views)
Thanks, I could get it. Also could you specify, if a for loop takes each element from the array by tunneling , then can it also output the array which is autoindexed. like we collect bunch of elements in an array in a for loop,can we tunnel them out one element at a time?
This will help immensely.
Thanks again
Ravi
Message 5 of 14
(4,601 Views)
Yes, an autoindex output tunnel will create an array of size N, one element per iteration.
Message 6 of 14
(4,596 Views)
Yes, using indexing on the input and output allows you to feed an array in one element at a time and collect the elements at the output into an array that will be passed out when the loop completes.
Jim
Jim
LV 2020
Message 7 of 14
(4,593 Views)
Thanks a bunch that solves my one problem.
Thanks again.
Ravi
Message 8 of 14
(4,589 Views)
But I have a little prob. here. When I run this VI, it works fine for the first time but second time I run it, it hold the previous value and starts incremtning on that. The problem to me seems in the for loop where I pass into format into a string.
I want that to be always zero intially and then pass on the value which ever comes from the user.
Ravi
Message 9 of 14
(4,585 Views)
You need to initialize your shift register (feedback node). Connect a zero to the left terminal (with the diamond) outside the loop.
Lynn
Message 10 of 14
(4,580 Views)
