Using a waveform graph, how to get all recorded data graphed?
I record data from 6 channels using DAQmx with simulated channels and write to measurement file.  Then using read from measurement file, and waveform graph, I am trying to graph the data that has been recorded.  I am only getting a small amount graphed.  The same graph appears whether I have let the measure and record program run for 1 minute or for ten minutes.  It also displays a time at the end of the graph that is in the future.  What am I doing wrong?  Please help.
Hillis Pratt, Jr.
(2,982 Views)
Why don't you post your code and an example data file?
(2,977 Views)
I am attaching the two VIs I have been trying to use.  I started with examples from NI and didn't go far from that.  Any assistance would be appreciated.
(2,952 Views)
In your write to File express VI, try setting the segment headers to one header only.
(2,943 Views)
Can you please attach the data file that you using? What type of measurement are you performing (AI voltage, AI current, AO)?
Warm regards,
Karunya R
(2,919 Views)
