Using a wiimote with LabVIEW
@Kovacs
Yes, we've run the Test.exe and it's telling us that everything is fine, it's picking up both the LED points and returning data properly. We've also tried using a new Wiimote and the same problem occurs.
Message 151 of 220
(3,983 Views)
@ Kovacs, It's all fine now, it seems there was a file misplaced/copied in the Wiimote library which was causing this mess-up. Thanks for your feedback anyway!
Message 152 of 220
(3,965 Views)
Good to hear!
I'm glad you found out what the problem was, I know how frustrating something like that can be.
Message 153 of 220
(3,957 Views)
Hmm.. okay so with a regular sensor bar I get two readings (629 & 156) for my Raw X Values, but when you unbundle the IRState on your block diagram, the "Raw X Values" element will only give you the first reading. How do I obtain the second?
Message Edited by Kovacs on 04-29-2010 03:16 PM
Message 154 of 220
(3,797 Views)
Maybe this helps? I opened the SubVI of IRState, but it's not giving me any ideas how to obtain the second Raw X Value (when using a regular (2 LEDs) sensor bar).
Since I can see the value being displayed on the front panel surely there's some way to get access to it.. or am I misinterpreting something here perhaps?
Message 155 of 220
(3,767 Views)
I'm not sure what you mean by the second raw X value and where you want to get this from.  But it is probably just a matter of using unbundle by name and index array properly.
Message 156 of 220
(3,749 Views)
Index Array.. turns out that's exactly it.
Thanx!
Message 157 of 220
(3,739 Views)
I don't suppose it's possible to connect the same wiimote to two different computers, right?
I'm aiming to use the wiimote on one computer and collecting data with it on another (where LabVIEW is installed) (both of them on the same network).
I think I have to come up with something else.
Message 158 of 220
(3,433 Views)
What do you mean by using the Wiimote on one computer and collecting data on the other one? Because in both ways you are using the Wiimote.
Ps. You can let the computers communicate together 😉
Message 159 of 220
(3,398 Views)
Hmm.. so what you're saying is I could connect the Wiimote to one computer and then use TCP or something to get the signal across in order for LabVIEW (installed on the other) to read the wiimote data?
I'm using the VIs created by S. Shearman, it's not necessary to use them from the same computer where the Wiimote is connected to (as long as I can get the wiimote signal to it)? (Please excuse my ignorance, I'm not that technical but I'm trying.)
Message 160 of 220
(3,387 Views)
