Using a wiimote with LabVIEW
Hello JohannS,
I am having trouble in getting the vis running. I am completely out of practice in programming LabView (I only downloaded the Evaluation Version). Can you support me with a complete vi for setting up the wiimote and reading especially the infrared-point data.
I have the wiimote connected (Broadcom 2045 Bluetooth 2.0) and I can work with the vis from sshearman. But  don't get any results from your vis.
Regards
Maenne
Message 41 of 220
(11,150 Views)
Which set of VIs did you download from the post? I would recommend you to look at the ones that have been posted on the Wiimote Driver Wiki.
The examples that are included with the Wiimote VIs would be a good starting point for building your application. The Usage IR Sensor.vi will be the more specific to your particular application.
I hope this helps!
Mehak D.
Message 42 of 220
(11,090 Views)
Okay, this is cool.
What's cooler is how I'm getting data from the wiimote without using the Microsoft btstack.  I'm not sure how I'm doing it, but I am.
I have a Belkin FT012xx1 BT dongle and it uses Widcomm btstack.  I could at the time only use GlovePIE to interact, but I really wanted to get Labview to recognize my controller.
Everytime, I would get an error from the "Wiimote Set Output Report.vi" and the Input Report vi.  So, out of curiosity, I went into the VI and changed it so that it would not pass on any errors.  What followed amazed me.  It ran.  Not only did it run, but it also knew what LEDs on my wiimote were on....Smiley Surprised
After some observation, I was running GlovePIE simultaneously and only those elements that my script was using in GlovePIE were the ones LabView had access to.
So, basically, I think if you can connect some other way to GlovePIE and just put a script like:
if wiimote.dot1vis then
endif
for each of the elements you want to enable, then Labview might have access to it.
I'm ecstatic about this. I overcame the Microsoft BTStack barrier! I just did it tonight (erm, or this morning) and so I still need to play around with it just to make sure. Maybe I'm dreaming. I haven't been so lucky in a long time.
Message 43 of 220
(10,977 Views)
Hi all,
Is there a 'Master VI' that should be run or are these merely sub-VI's that should be wired up? I currently have the Wii linked up and am looking to gather, initially at least, some accelerometer data and write the data to file. Thanks!
Tyler
Tyler C. | Certified LabVIEW Associate Developer
Message 44 of 220
(10,915 Views)
Apart from the Usage VIs, most of the VIs included in the zip folders are VIs that should be used as a part of a larger application. Refer to the usage VIs included in the zipped folders for examples on how to implement the VIs as a part of a larger application.
Mehak D.
Message 45 of 220
(10,867 Views)
I am pretty new to this, so it might be a stupid question but Is it also possible to get the intensity of the IR-sensor within Labview? I see it is a possibility of Wiimote (http://wiibrew.org/index.php?title=Wiimote#IR_Camera) but can I also do this with the files you provided?
Message 46 of 220
(10,759 Views)
Hi I'm a very new user to Labview, currently having alot of problems messing with the VIs. Does anyone have a working sample on using the Wiimote to remotely control the lego tribot where I can just compile and load it into the NXT?
Help is very much appreciated, thanks! 🙂
Message 47 of 220
(10,571 Views)
Hello Ryany,
If you are new to LabVIEW, I suggest that you read through the many tutorials that are online.  You can even think of taking a LabVIEW Basics course
You can take a look at the code that controls the Roomba that other ppl have posted earlier in this thread, and modify it as required.
Has anyone else used the wiimote to control a Lego NXT?
Kameralina
Message 48 of 220
(10,516 Views)
Dear sshearman
                            I have used your program WiiimoteLib121test (events).vi,It can work (with the blusoleil)
                            could your tell me
                            How could I send the X Acceleration data to a new Indicator(not to the wiimotestate.ctl)
                            because i want to send the data to the 8051 microchip
                            Could you give me a example to do that
                            The Attached file is my vi file changed from your  WiiimoteLib121test (events).vi
                             But  the X Acceleration data could not changed repeatly
                             Thanks for your help
hsiaochung@cc.chit.edu.tw
Message 49 of 220
(10,198 Views)
Hello hsiaochung,
I suggest starting with the other main example included with my LabVIEW code, "WiimoteLib12test (polling).vi". It polls the driver for the data from the wiimote and is more straightforward than the event-based example, which waiting for an event callback to get the data.
If you work with polling example, you can pull the acceleration data from the cluster directly from the Wiimote state cluster.
--Sam
Sam Shearman
Message 50 of 220
(10,162 Views)
