Using an ActiveX Server build with LabVIEW as automation class in LabVIEW?
i tried to use an ActiveX Server (built with LabVIEW 7.0) as ActiveX class of 'Automation open' VI.
I get the error message - Automation Open: Object specified is not creatable in xxx.vi
Openning a reference to TestStandLVRTS built in an older version of LabVIEW is possible without
any error messages.
Can an ActiveX Server built with LV be used as automation class in the same version of LV?
Does this work inside another ActiveX Server build with LV too?
Sunny
(2,661 Views)
calling of such an ActiveX Server seems to work now.
Sunny
(2,653 Views)
