Using an array with an expression node on a PDA
I'm having a problem deploying an application to my PDA (pocket PC 2003) when the block diagram has an array wired to an expression node.
When I try to build the exe I get the following error:
retrun is a missing VI or C file.
Attached is an example VI that produces the same error
Thanks for the help.
Eric
LV 8.2
PDA Module 8.2
(10,901 Views)
After having some experience with the PDA module, I can say that this is most likely a bug even without looking at the code. My reasoning is that if this was unsupported functionality it should have broken your VI and not allowed you to build it.
You should probably change your code.
___________________
Try to take over the world!
(10,887 Views)
Thanks for your reply,
I agree with you I think it is a bug as well.  But the expression node does work with a single numeric value and it is on the PDA function pallet.
I've already changed my code to work around the expression node I was using.
Thanks again
Eric
(10,864 Views)
This is an issue known prior to release - it is documented in the PDA Readme file:
Open the LabVIEW Readme files folder by selecting Start»All Programs»National Instruments»LabVIEW 8.2»Readme, and then open readme_PDA.html.
Search that html page for "expression node" (without quotes) and you should find this issue acknowledged as the 8th bullet under the section entitled "VIs and Functions Known Issues."
Best Regards,
JLS
Best,
JLS
Sixclear
(10,863 Views)
I found it.
If all else fails read the directions.
Thanks again
Eric
(10,852 Views)
