Using bar code scanner
I am using a USB interface barcode reader. I have successfully connected this to labview, that is, when I scan a code, it is displayed in the control string. However, for some strange reason, the control string at that moment only displays the very first character of the code, for example for the code "5032608001610" i got only "5" in my string. when I ran the VI again i got the full string in my indicator. It is like during the first execution the value is not obtained then during the second execution (without scanning) I get the first scan.
can someone help pls? here's the VI...
Message 11 of 15
(2,486 Views)
Since you're checking for empty string in your loop it's no wonder it'll stop early. 🙂
Place a event structure with a value change event for the string control, it'll make your life alot easier. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 15
(2,484 Views)
Hi Sumithra_Nagap…
                                  Any working sacanner will work with labview also.. For verification open one notepad and scan any code. It should write the scanned code with enter at last..
Take reference of this VI..
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 13 of 15
(2,481 Views)
hi ranjeeeth singh..
 Thanks for your piece of information.By the way i have solved this issue an year back.
Message 14 of 15
(2,401 Views)
hi
I am basic Lerner of labview.. can any one explain me how to programmed for scanner?
I want to scan barcode & Compare, tell result.
please explain me.
sati
Message 15 of 15
(2,076 Views)
