Using change properties of a control dial, why can I not feed the output into the Sial input (via a loop ) and the dial continually updates?
This should do it.
If you are going to change the value of a control programatically, you do have to use either a local variable or property node. Best to use a local variable if you are only going to use teh value property, it's bit more efficient.
This now watches also for the channel selector to change and reads the value from the array of the selected channel and writes it to the control via local variable.
The Event Structure does away with polling for most applications.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 11 of 13
(718 Views)
Thanks guys!
It all looks so simple!
Wish I had a brain.
Many thanks and best wishes
Derek
Message 12 of 13
(715 Views)
Fossetics wrote:
Wish I had a brain.
As you wish...
___________________
Try to take over the world!
Message 13 of 13
(710 Views)
