Using comport data to start a sequence
Altenbach--
      I most certainly can. The VI is in LV 7.1 Any tips you give are appreciated. Why is using "string to path" and path to string" and issue. I have used it before without a problem. I thought about the arrays growing w/o bounds but have not addressed that yet. I am going to try to get rid of all the locals by using clusters and shift registers. Haven't done that before because this is the first program if worked on with this many data variables. The parallel while loop is gone but I still need a way to get the clock to update once per second rather than once per read, which is currently once per minute. I believe I fixed the opening of the file each read. I now do it before the main loop. Thanks in advance for the help.
ssmith
Message 21 of 27
(1,875 Views)
ssmith490D wrote:
Altenbach--
Which do you think is easier to code:
Hard-coding paths using strings makes it non-portable across platforms. As it is, your code will only run under Windows.
Also,
You started another thread asking about how to sum up elements over the past 4 hours, which is clearly related to this. You are assuming it's once per minute. You cannot guarantee this. You loop is software-timed, and as such it will be a slave to the operating system's whims and fancies, like deciding to do a Windows update check, or an anti-virus check, or...
Message Edited by smercurio_fc on 12-27-2008 09:47 AM
Message 22 of 27
(1,856 Views)
smercurio--
     Thanks for the tip about using path functions. I never considered different platforms. I didn't think I could create an app on a windows machine and then use it on a mac or unix machine. Aren't there issues when building an installable application?? It does look simplier to create the path also. I don't see how summing the last "n" elements in an array is similar to updating a clock once per second. What am I not seeing here??  I had the clock in a separate while loop running parallel to the main loop and it worked, but I had 2 stop buttons, one for each loop. Didn't like that. I tried using one switch and changing the switching mechanism and it never seemed to worked correctly. As for the timing thing. Data arrives at the com port once per minute when the Campbell data logger sends it. The read is triggered by the arrival of data. Since the clock is in the read case the clock updates at the same time. That is how it works, right?? I understand that there might be a small delay if the anti virus or updater is running. If it takes a couple of seconds longer to update the clock it should still update with the correct time, right??Thanks for the help.
Scott
Message 23 of 27
(1,850 Views)
So, if data arrives once per minute, small timing differences are probably irrelevant. You should take the (orange) time after the data has arrives. This way you can combine it with all the data as a row in your 2D shift register. Please get rid of all these hidden arrays!
If the times are approximately regular, maybe you can use charts. It would really simplify things.
Do you have a typical raw sample string as it arrives from the serial port?
More glaring mistakes:
  • You need to initialize the shift register in the inner loop
  • You need to wire the VISA resource across ALL cases of the case structure. RIght now, if you stop the VI while it is in another case, you'll get an error closing the resource, because it is invalid.
I am not a hardware guy, but your visa stuff looks odd. You are waiting for long times, during which the clock on the FP does not update.
About the summing of the last N points. It also makes little sense. Do you want a running average? Do you want to decimate the data in some way? It is difficult to see what the sum of N windspeeds or direction angles would mean to the observer. 😉
Message 24 of 27
(1,843 Views)
Altenbach--
        I initialized the shift register in the inner loop. I continued the VISA resource through all the cases. I also continued the error wire through all the cases. Is that right? The summing of points is for the rain gauge measurement only. A tipping bucket tips when .01" of rain is collected. Most of the time the one minute readings will be zero. It is useful to see how much it has rained over the last n hours. As for the arrays...I don't know what to say. I need the arrays so I can plot them against time. If, for some reason, data stops for a period of time the plots will show that break in the data. I don't think you can do that with a chart. One of things I want to work on is using clusters and shft registers instead of locals. I've attached the current VI(7.1) and a text file with some data. I added the breaks between the last 2 data messages so you see what one message looks like. Each message has 5 lines with 8 fields of data. They are numbered 01,02,03, etc. The rest of the file is as created by LV, which is how the post-processing routines want to see it. Thanks again for all the help and comments. You will be kudoed.
Scott
Message 25 of 27
(1,833 Views)
I don't have time to look at your VI at the moment, but you can have gaps in charts. Just feed it NaN instead of data for the missing points.
For the summing of points, all you need is a single scalar in a shift register where you add the incoming values with each iteration.
Message 26 of 27
(1,830 Views)
If you sum points using a shift register how would you control how many points to sum. Say you want to sit down in front of the computer and find out how much rain there was in the last 3 hours. Then you want to know how much rain there was in the last 24 hours. The way it is now I can move the switch to Total, put in the requested number of hours past and on the next iteration of the main loop the total for that time period is displayed. I don't want a running total, switch I think I would get using the shift register method. Thanks. Your input on the VI as a whole is appreciated.
Scott
Message 27 of 27
(1,821 Views)
