Using data entry limits on multiple digital inputs
I'm trying to set data entry limits for several digital input fields. Whenever I set the limits for one, the same limits are applied to all the other inputs on the front panel.
What am I doing wrong?
Bob
(2,770 Views)
What version of LabVIEW are you using?  Is it 8.6 or 8.6.1?
You may be seeing this bug.  Data Entry Maximum and Minimum affects all objects on front panel?
If it is this.  It is more a bug with the dialog box not properly setting the current values of the properties when it loads.  The data entry limit properties of the other controls are actually still the same as they were.
(2,762 Views)
The patch fixed the problem.
Bob
(2,741 Views)
