Using different sources to display on the same indicator
I am using three slide bars and three different mathematical equations using the same indicator bars. I would like to control each equation with a different control button. When I hook up the output of each mathematical equation to the same indicator, I get indicators saying there can only be one output hooked to an indicator. Is there anyway around this??
(2,900 Views)
"BeginnerCoder" wrote in message
news:506500000008000000665A0000-1027480788000@exchange.ni.com...
> around this??
> Thanks
Could you put the 3 equations in a case statement?
(2,900 Views)
To elaborate on the previous poster's suggestion, I wrote the attached example
Jeremy
(2,900 Views)
