Using digital IO to start and stop triggering
I just read the article and tried the example listed in the following link:
However, I would like to set the sampling rate and got no idea where should it be placed. Any idea on that  ?
Michael
(2,803 Views)
Michael,
You may find this [example no longer available] link a little more helpful. It uses our new NI-DAQmx driver, as opposed to our older Traditional (Legacy) NI-DAQ driver. The example in the link has a "Rate" control, which sets your sample rate.
Please let us know if you have any questions about this process. Note that it is a bit of a hack, and not representative of the usually very clean and efficient DAQmx code.
Hope this helps,
Ryan Verret
Product Marketing Engineer
Signal Generators
(2,783 Views)
