Using external clock on sbRIO 9606
I'm trying to use LTC2170 ADC with sbRIO 9606. The ADC chip has serial data outputs, a frame start output and a data clock output. How can I use the frame start and data clock outputs of the ADC in LabVIEW to read serial data bits from the ADC? The shifting in of the serial data should start with the frame start output of the ADC and each bit should be shifted in with the data clock output of the ADC.
(2,854 Views)
http://zone.ni.com/reference/en-XX/help/371599D-01/lvfpgaconcepts/external_clocks/
(2,826 Views)
