Using labview applications on mobile phones
I am interested in using LabVIEW applications on Mobile Phones. Kindly suggest how it could be used and which type of mobile phones are suitable it.
Message 1 of 10
(5,449 Views)
Pls reply
Message 2 of 10
(5,428 Views)
You might want to consider this.
Message 3 of 10
(5,420 Views)
But i am intersted in using the availble mobile phones.
Not using the NI Mobile module.
Message 4 of 10
(5,417 Views)
Hi Intelligent,
The LabVIEW Web UI Builder can be used for creating web applications that you can access on a mobile phone.  Is that the kind of thing you're looking for?
Have a great day,
Chris V
Message 5 of 10
(5,405 Views)
Actually i was interested in utilizing the processor of a mobile phone to process the data. That is to replace the PC with a mobile phone.
Message 6 of 10
(5,396 Views)
Intelligent said: "Actually i was interested in utilizing the processor of a mobile phone to process the data. That is to replace the PC with a mobile phone."
So, is this project realizable using labview or not ?
Message 7 of 10
(5,385 Views)
Hi Intelligent,
National Instruments has a Mobile Module for developing applications specifically for mobile devices.  Check out this article for supported devices: LabVIEW Mobile Module Software Requirements and Supported Devices.
In addition, if you device runs Windows XP Embedded, you should be able to install the LabVIEW Runtime Engine and then run an executable built in LabVIEW.
Have a great day,
Chris V
Message 8 of 10
(5,362 Views)
I want to use it on an ordionary mobile phone like that of one Nokia.
Message 9 of 10
(5,342 Views)
I'm not sure what else you need. You've gotten the OS list. Vendors provide phones with a variety. If your phone is running one of the supported ones, you can use LabVIEW Mobile to create an app. Otherwise, leave the processing on a much more powerful host and view/control the app from your phone.
Message 10 of 10
(5,335 Views)
