Using labview to fill in a Between [start] And [End] criteria in an access query
I am trying to use the database connectivity toolkit and the execute query vi to fill in criteria in an access query:
Between [Start] And [End]
I have successfully used the execute query vi to fill in one variable, for example Enter Part Number [Number] by combining the query name in a string with the input variable in quotations.  I can't figure out how to enter two variables though.  I've attached a picture of the query I'd like to run using Labview.
Any help is appreciated.
Thanks.
(2,530 Views)
Use "format into string" or string concatenation operations to insert the criteria into the SQL query text.   In ACCESS, you can click on something -- I forget exactly what -- that will show you the SQL that corresponds to the query you have captured from design view. Take that ACCESS-generated string and replace your criteria with '%s' as I did in the attached example.
(2,518 Views)
Thanks for the reply.  Any chance you'd be willing to upload a picture of your code, I'm still on LabView 8.2.
Thanks again.
(2,515 Views)
saved for 8.2 below.  Also a block diagram screenshot in case it doesn't open for some reason.
(2,502 Views)
