Using labview with Agilent 82350A GPIB card
 Helllo
I have a question regarding my Agilent E2078A/82350A GPIB card with Labview. I used the card as the interface between my oscilloscope and PC. My intention is to use the data observed from the oscilloscope and program it in Labview  . The card was not detected in Max then I could not poceed with the programming. Is there any way to configure the Labview so it can detect and get the data from Agilent GPIB card? I found some reference links here which relate to my problem but they are all broken.
Hope someone can help me out. Many thanks and appreciation.
(3,364 Views)
You need to enable tulip support in MAX. I believe that Agilent has complete instructions as well.
(3,360 Views)
