Hi everyone,
I have the following problem when I tried to control BSC203 with LabVIEW. Sometimes (it seems to be a little random), some devices are not enabled (even though I use "CreateDevice" and "EnableDevice" methods), so an error happens when other methods are run.
Directly using Kinesis, if I try to push the button to enable the device, it doesn't react, nothing changes.
In adiction, pushing the enable button in the front planel of the controller doesn't make any change either in Kinesis.
The only solution that I found is turning off and on the stepper controller several times until it works again.
Any idea of where the problem comes?
Thanks in advance!
