Using large datasets in python node
I would like to run a UMAP dimension reduction algorithm (https://umap-learn.readthedocs.io/en/latest/) in LabVIEW using python node. I succeeded to run the UMAP code, but when inputting data with a large size, it causes an error with an error code: 1672 (see attached). Typically, in my computer, there is no error when using 100000 x 100 float data, but it causes the error when using >200000 x 1000 float data. I would appreciate if you could give me advises. Attached is LabVIEW program, and the following is a python code (named as functions3.py) to communicate to the UMAP code.
import umap
import umap.plot
import numpy as np
from sklearn.datasets import load_digits, load_sample_image, load_sample_images
def lv_umap(dat,param0,param1,param2):
    dat1 = np.array(dat);
    dat2 = umap.UMAP(n_neighbors=param0,n_components=param1,min_dist=param2).fit_transform(dat1);
    dat3 = dat2.tolist();
    return dat3;
There is no error when running the UMAP code in python, so I consider there should be a problem in the LabVIEW code, and I guess there may be  a size limit in python node. Also, the line 4 "from sklearn.datasets import load_digits, load_sample_image, load_sample_images" seems unnecessary, but it causes an error with the same code (1672) and the same message when deleting this line even when using 100000 x 100 float data.
(3,170 Views)
Accepted by topic author ytan
So, the data transfer between LabVIEW & Python node is not meant to handle massive arrays. The best way to handle this is to write the data to a file in LV, pass the file path to Python, read the file in Python, store the processed data in another file, and return that path to LabVIEW.
Santhosh
Soliton Technologies
(3,158 Views)
Thanks so much for the answer! I solved the issue by writing/reading the files as you suggested.
(3,071 Views)
