Using list file?
If "list file" outputs an alphabetically sorted array, is there a convenient function to list the directory of files by creation date?
Message 1 of 9
(2,348 Views)
Hey, you will have to write this function.
the way of getting the creation date of file is that:
good luck.
Message 2 of 9
(2,329 Views)
I think that "List Folder" doesn't do any sorting.  It just returns the files in whatever order it gets them from the OS.  You shouldn't make any assumptions about what that order is.
Message 3 of 9
(2,290 Views)
Well I might've got off on a tangent and didn't really realize that yes the OS that does that sorting.. Thank you
Message 4 of 9
(2,285 Views)
Of course you can sort by any other feature or filename part. Here's how you would sort based on last modification date.
Message 5 of 9
(2,239 Views)
Well I think that's become the most useful solution out of the three so thank you everyone I'm up and running
Message 6 of 9
(2,228 Views)
Did’nt you ask for creation date?
Message 7 of 9
(2,223 Views)
My code was a generalized example and, as I said, the sorting can be done on any file feature as long as you can get it from somewhere. 😄
Message 8 of 9
(2,217 Views)
Yes shortly after I sent that I realized maybe I didn't quite ask what I was looking for exactly but what you folks have sent back to me I've made work with
Message 9 of 9
(2,215 Views)
