Using mono 8-bit data acquired from a soundcard as an input to the single tone extraction vi
Hello there, I am a complete novice and was wondering if anyone can give me any advice as to how I convert the data acquired from a souncard into a time signal which I can input to the tone extraction vi, (I am intending to replace the static signal which the tone extraction vi takes currently and replace it with a continuous signal from the soundcard)
Em
(3,173 Views)
To convert any array which you have into a waveform data type you can use the Build Waveform function. Your array of values is wired into the Y terminal and you must wire the sample interval (1/sample rate) into the dt terminal. This will get you a waveform which you can use with Extract Single Tone.vi and any other Waveform Measurement vi's. Example attached.
Ian
(3,173 Views)
Hi Ian, thanks for the reply, I don't suppose you have a copy of the example for LabView 6.0 do you? as I received a load error when I tried to run your VI.
Thanks in anticipation
Em
(3,173 Views)
Attached is a version of the VI saved for 6.0, original was in 6.1. (I haven't tested it as I no longer have 6i on my machine but it should work)
Ian
(3,173 Views)
Thankyou, that was a tremendous help! (Using the DC elimination was useful too!)
Em
(3,173 Views)
