Using multiple USB cameras for vision inspection
I am working on a vision inspection project in which I have to use around 12 USB cameras to capture 12 different images. I am getting so problems by conntecting these cameras with my computer as they are placed at a bit long distence (around 5 meters). I have tried  USB hubs and powered USB hubs but the still I am getting some problems. While doing a bit of reseach on net, I came across the term "Network USB Hub".
These are some product links:
http://www.belkin.com/networkusbhub/
http://www.maplin.co.uk/p/gigabit-network-server-4-port-usb-20-hub-n01jz
http://www.digitus.info/en/products/network/multifunction-network-servers/fast-ethernet-network-usb-...
Before I buy, I want know few things reguarding this "Network USB Hub",
  • Is this product compatible with LabVIEW?
  • Has anyone used it with LabVIEW?
  • Does it get displayed on NI MAX as NI MAX show other devices?
  • Is there any other effective way to handle these many cameras and which is also compatible with LabVIEW and NI Vision development module?
(2,901 Views)
I reperesent NET USA, INC
It sounds that you are running in a USB 2 port and do not have enough bandwidth
Please dont hesitate to contact me directly to assit you with your issue
800 266 5906
Milo
(2,809 Views)
