Using non linear unconstrained optimizers
I am having an issue using the uncontrained optimization vi. I have used the template for the objective function provided but I can't seem to get it to work. My error message says "LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @."
My application is to find an optimum set of quaternion parameters which describe a rotation between 2 vectors. The vector in this case contains six elements as there are 2 vectors (1 each from individual sensors). To begin with, the obj funciton should be equal to zero (no rotation) and I input the correct quaternion describing this into the optimizer (hence solution is already a minimum??).
But when I run it, the control within the obj function describing the quaterion parameters is NaN and not what I wire to the "Start" input.
Does anyone know what is going on and is able to help me?
Thanks very much,
Tom
(code is attached)
(3,417 Views)
Hi tlin067,
I am having so trouble running the code you sent. It appears I am missing Quaternion to Rotation Matrix.vi. Could you resend the code and make sure all the subvi's are included.
Josh Brown
(3,388 Views)
HI Josh,
Thanks for the reply. That vi is part of the robotics toolbox. That may mean you are unable to help me?
Cheers,
Tom
(3,383 Views)
Hey Tom,
I am going to install the robotics toolbox and take another look at your code. I will get back to you when I have something.
Josh Brown
(3,374 Views)
Hey Tom,
So I installed the robotics kit and was able to recreate your error. I think I have figured out were it is actually happening. In your main vi open the Unconstrained Optimization. Then within this vi open Armijo rule stepsize reduction. Then within this open unco_function and gradient. Then open the call object fuction.vi. The error appears to taking place at the reference node within this vi. My computer was giving me the following error: call by reference node in NI_Gmath.lvlib:ucno_call objective funtion.vi:28. I believe this is the root of your problem so try to figure out what is going on with the reference node. I hope this helps.
Josh Brown
(3,359 Views)
