Using occurence to stop measurements but allow main program to peform analysis & printing of results
I am trying to use a higher level VI to take resistance measurements from the HP34401A DMM and be able to stop the measurements without stoping the high level vi. I found out about using occurrences and am trying to implement that method though I'm not sure this is the best way to go. Should I be using notifiers? I have LabVIEW 2011 Base.
I would like to do the following:
1. Start program & take measurements to infinity (which stops at 512 I believe) - note I cannot use the trigger count as this will be n which is why I need to manually stop the measurement process.
2. After measurements are taken plot the histogram and peform calculations (I have this part written but stripped it from the VI I attached to simplify it).
3. Have the user choose to press the print button and print the data to a sub-VI.
4. Stop the program.
Please advise, I'm still a noob at this!
(2,486 Views)
I saved the files to version 8.6.
(2,471 Views)
Hi elements,
Here are some resources which you will probably find relevant for your application. I would suggest spending some time looking trough them and deciding which is best for your particular case.
http://zone.ni.com/reference/en-XX/help/371361H-01/glang/occurrence_functions/
https://decibel.ni.com/content/docs/DOC-5211
http://zone.ni.com/reference/en-XX/help/371361F-01/glang/notification_vis/
http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/hndl_notifiers_loop/
Josh Brown
(2,437 Views)
