Using polar plot to plot distance/angle pairs
I am attempting to show updates of distance/angle pairs on a polar plot.
The data comes in as a single distance/angle pair, and the plot should
simply add the new point to the existing data.
To do this, I have created an instance of a polar plot. The following
details the inputs:
Data Array: a pair of distance/angle values that are put into a Cluster
and then an array.
Dimension: Numeric Controls with width set to 500 and height to 425.
The values are fed into a cluster and then to the polar plot.
Top Left Point: Numeric constants (0) fed into a cluster and then to the
polar plot.
Polar Attributes: A Cluster is fed to the polar plot. The cluster is
made up of the following:
A Numeric control, defaulting to 4000
A numeric constant set to 0
A boolean constant set to False
A color constant set to red
A color constant set to white
A cluster containing the Enum "Decimal" and a constant of 8
A constant set to 8.
When I attempt to save the VI, I receive an error message and the
following data in a file:
#Date: Mon, Feb 11, 2002 10:59:31 AM
#Desc: Failure : "fpsane.cpp", line 269
LabVIEW version 6.0
For assistance in resolving this problem, please record the preceding
information and navigate to www.ni.com/failure, or contact National
Instruments.
#RCS: $Id: //labview/releases/6.0/lvsource/fpsane.cpp#2 $
#OSName: Linux
#OSVers: 2.4.2-2
#AppName: /usr/local/lv60/labview
#AppKind: FDS
0x08110676 - DBSetDebugStrings() + 0x2a
0x0811063d - DBAssert() + 0xb1
0x082f0cfd - ReportInsanities__Fi() + 0x85
0x082f0bde - SanityCheck__FPPUc() + 0x192
0x0851b506 - VerifyVIPieces__FPP10INSTRUMENTUii() + 0x54a
0x0851cf24 - HasNewAutoTDs__FPsi() + 0x1590
0x08519d6e - SaveInstrument__FPP10INSTRUMENTUiPP6Path_tPPPUc() + 0x122a
0x085189c8 - SaveVI__FPP10INSTRUMENTi() + 0x48
0x085dadd3 - OpenVINoDlg__FPP6Path_tPPP10INSTRUMENT() + 0x1c3
0x085e1011 - ResetLVCursor__FPPUcP5Pointi() + 0x4f9
0x085da565 - VIWinProc__FP6WEventi() + 0x2a5
0x0818745d - WSetEventProc() + 0x49
0x081877ee - WSendEvent() + 0xba
0x0818772d - FocSendEvent() + 0x7d
0x08185399 - XNewWindow() + 0xcc5
0x08186eae - WTriggerBGAppTasks() + 0x26a
0x08187de2 - WMainLoop() + 0x5e
0x0814a360 - PostOpenVIDocEvent__FPc() + 0x3b4
0x0814a41b - main() + 0xa3
0x40254177 - __libc_start_main() + 0x93
0x08105bb1 - _start() + 0x21
Can anyone tell me what Is wrong with my VI and how to fix it?
TIA
Rich Hilt
(2,995 Views)
I would first suggest updating your version of LabVIEW to 6.0.2. Be sure to mass compile your personal VI's after updating LabVIEW. If this does not solve the problem try copying the entire block diagram of the problematic VI to a brand new VI. If this does not solve the problem you can send the VI to NI and an engineer will look at it.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,995 Views)
