Using "Set Control Value" to pass a reference
every time I tried to passe a Control Reference using "Set Control Value" I have the Error 1 (invalid input parameter at invoke node). Why is it not possible to pass a control reference using the invoke node??
Golzio
(2,863 Views)
This is possible. Trick is, the type of the control reference needs to be
the same as the input. E.g. a string control reference is a different type
as a numeric control reference (, or a control reference).
To avoid this conflic, make sure the input of the vi is a control reference
(and not a e.g. string control reference). Also make sure the to convert the
reference you pass to a control reference (using Application Control>To More
Generic Class).
Wiebe.
"Golzio" wrote in message
news:506500000008000000C1F00000-1079395200000@exchange.ni.com...
> Hi,
> node??
> Thanks
> Golzio
(2,863 Views)
