Using refprop tables in LabVIEW
I am developing a program that has to convert temperature to pressure using tables generated by NIST Refprop. Has anybody already developed this routine?
(4,602 Views)
Hallo, Ronaldo,
Du (x) meintest am 20.12.01:
Big and fast: use look-up-tables.
Greetings!
Helmut
Please excuse my gerlish!
(4,601 Views)
I was wondering if anyone has ever completed an application accessing REFPROP from NIST.
I have used other DLL’s with the CIN tool but can not seem to make this REFPROP DLL work.
If anyone has a code snippet showing the settings of the CIN tool that is using REFPROP, it would be greatly appreciated.
(4,510 Views)
I managed to get labview to read fluid properties from Refprop, but only for a pure fluid refrigerant (CO2, R134A etc.) but not for a mixture. There is some way to call the DLL's to set up for a mixture, but as yet I haven't got this to work. There seems to be a discrepency between the calls on the DLL in the labview program that they sent me, and the documentation on this DLL.
If you want a VI that sucessfully pulls data on a pure fluid from Refprop, I can sent one on to you.
Alternately, if you know how to read data on a mixture, I'd really appreciate a dig out on whatever small thing that I'm doing wrong.
Will
(4,350 Views)
