Using sb rio GPGA for gyroscope
Ok it seems that there are still some little issues in the program,
I think I already had the current version running, cause I started to write the report, but now the second part of my flat sequence structure does not get activated anymore.
I do not know why, because the structure part before gets just runs a forloop and saves the calculated values into an indicator and a shared variable.
Could you please take a look at that?
Regards
Andreas
Message 21 of 22
(645 Views)
error was due to the applied tunnel for the stop condition. The sequence structure only executes if all information required is passed through the tunnels.
Andreas
Message 22 of 22
(623 Views)
