Using serial port to send AT commands
I am trying to communicate with a serial device( GSM modem).I use the serial port (com 1)to send an "AT" command but when I read the serial port,I don´t read the right answer ( it must be an "OK" ),but I read the command I am trying to send instead of the right one.
(3,940 Views)
No time now to down load your code and look!
THis sounds like your modem is set for local echo.
Check the switches etc.
In "Local Echo" mode, every character typed was echoed by the modem. This was used in the "Old Days" when we used to use dumb terminals. The echo let us know what we typed.
This can also be set "Off" on some modem via an AT command. Sorry, I don't remeber what the command was.
Along with the above, the "OK" should not come back until after the modem sees an Carridge Return (enter).
Some modems where also "case sensitive". Watch for that.
Ben
Ben
(3,940 Views)
On some platforms you may need to send a linefeed after AT.
(3,940 Views)
