Using signals and Equations
I have an equation like this: y'=Q-3y, when Q is a signal comming from Analog Input or simulated but not convencional, such as square pulses with dampings.
My question is which equation VI do I need to use in Labview that will use this signal "Q" as input parameter and perform the equation y'?
Dalia Russek
Senior Technical Support Engineer
National Instruments ISRAEL Ltd
(3,150 Views)
Can't you just use the multiply and subtract nodes?
What is "y"?
(3,150 Views)
Hi, y' is just a mathematic parameter from the equation. I just put a simply equeation to demostrate what I ment, but its usually more complex such as y'=Q-5y-6t-t'. Not always is the same equeation using n-parameters and their derivative. I just thought to use ODE equation or any other mathematic vi, but I didn't know how to give a signal as input parameter. However, the operator vis can be a simple solution.
Dalia Russek
(3,150 Views)
