Using the CANopen library in LabView to implement a VI in a node that serves as slave.
We are working on a project using LabView and the CAN bus. I do also have the CANopen library for LabView. I would like to ask if anyone knows how to use this library in a way that one node acts as master and the others as slaves. Is this possible? In which way do I have to configure the
blocks? Could anyone provide me with an example?
Thank you very much
(2,903 Views)
the LabVIEW CANopen Library only provides functions to implement a CANopen master.
To implement a slave device you will have to use the basic NICAN VIs.
Some people have already done that and may be willing to provide you with some example code.
There is a special forum CAN & Device Net for this topic, you should ask there.
Anke
(2,901 Views)
